Why Can't I Enable Versioning?
1217
07-19-2019 11:01 AM
KyleLawhorn
I'm using Arc 10.5 (Catalog/Map)
I've created my enterprise geodatabase, I've loaded data into the geodatabase, and now when I go to enable versioning the options are not able to be selected?
How do I register this data as versioned?
RachelSears
Hi Kyle,
Are you the data owner of the dataset? The option to register data as versioned is only available to the data owner.
If you are the data owner, do you have a Standard or Advanced license? You cannot register data as versioned with a Basic license.
Source: https://support.esri.com/en/technical-article/000012497
Hope this helps.
-- Rachel
KyleLawhorn
No.
I realized my issue after I submitted the question. I signed in as the DBO and now I'm able to register it as versioned.
Thanks for your help.
