The answer is in the
$CATALINA_HOME variable! in my case /var/lib/tomcatx folder.
when you look up the variable, you get where the home dir is then you can find the webapp dir.
not sure why my "find" command didn't work, but hopefully this helps someone else
thanks for your help, guys!
