Where should i get server path, Problem in publishing
3806
03-29-2016 10:36 PM
NAGARAJNIDAGUNDI
c1.PNGTutorial: Publishing a map service—Documentation (10.3 and 10.3.1) | ArcGIS for Server
I refered the above link, im not getting how to get/find the Server Path, its asking when ArcGIS Map publishing.
RebeccaStrauch__GISP
Nagaraj, there isn't any advantage to asking the same question
(duplicate of Arc GisMap asking ArcGIS Server path while publishing )  since basicaly the same user will see it.  If it has been sitting without any looks for a while, you can just add a comment with a "bump"  but in the same thread.
you may just want to delete this one.
NAGARAJNIDAGUNDI
tunneppa, module answer heli matadu...
JayantaPoddar
Try
http://<Full_Machine_Name>:6080/arcgis
and provide the login credential (Administrator/Publisher) for ArcGIS for Server site.
Think Location
