Where is my Service Editor window?
6410
10
10-19-2015 02:58 AM
HarmenKampinga
Hi, When using ArcMap Advanced 10.1 SP1 I like to share my map by overwriting an existing ArcGIS Server service. The following steps I've taken: 1. File > Share As > Service... 2. Window [Share as a Service] opened and select 'Overwrite an existing service' 3. Then in the next window select the service to be overwritten 4. Select Continue.... .....but then nothing happens. The Service Editor window is not opening. But I can proceed with ArcGIS... When selecting the service in ArcCatalog, I can actually open the Service Editor window and adjust the properties if I want to.... Somebody knows what's going on?
Sanjeeva_ReddyYanala
I have also same problem, But i am facing the problem in both ArcGIS Desktop and ArcCatalog. In both cases, i am not able to get service editor window. I hope if you get the solution please share it with me.
Best Regards,
Sanjeev
