If the IP of the VM host changing, or is the IP of the GIS Server hosted on the VM host changing?
Honestly, unless some resource is being referenced via IP and DNS is working properly, there should be no impact. If the HOSTNAME of the GIS Server changes, you'll need to re-register the web adaptor and re-create your HTTPS certificates.
Are you experiencing any issues?
Thanks for your reply.
IP of the VM host will change and DNS will not change.
I didn't test and planning test after changing IP of VM.
