WebGIS DR Backup Operation Failed
3058
03-12-2020 03:14 AM
by Anonymous User
Not applicable
Hello everybody,
I was trying to use the WebGIS DR Backup Tool to create a backup of a Base Deployment for a ArcGIS Enterprise Installation. I used the Enterprise Builder to install the deployment on a Ubuntu 18.04 Server running in the Microsoft Azure Cloud. Both the Portal and the ArcGIS Server are running behind a Web Adaptor.
When starting the WebGIS DR utility,  the ArcGIS Data Strore is sucessfully backed up, but for the ArcGIS Server I get the error message:
Failed to back up the ArcGIS Server:
Url: https://xxx.westeurope.cloudapp.azure.com/server.
{"code":500,"messages":["Export operation failed. null"],"status":"error"}
I did change the log level of the ArcGIS Server to Debug but did not get any helpful information. The severe error only says:
SEVERE Export operation failed. null
There is also a DEBUG message that says:
java.lang.NullPointerException
I tried some stuff, like changing the portal url in the configuration from the webadaptor url to the internal url and specifying the port but no success.
Does anyone have any ideas? If you need any more information just ask.
Thanks in advance.
JonathanQuinn
Esri Notable Contributor
Looks like you may be running into BUG-000113339 - The ArcGIS Server 10.6 (or 10.7.1) export site operation returns the error message, "Export operation failed. null" within Amazon Web Services (AWS) on Microsoft Windows and Linux (or Azure). The only workaround is to remove the cloud based data store prior to running exportSite.
JonathanQuinn
Did you register any cloud stores? Can you post the full stack trace? There's an issue with creating a backup if you have registered a cloud store.
by Anonymous User
Not applicable
Hello Jonathan,
yes, a Azure Blob Storage is registered as a data store. ArcGIS Server Manager says its valid.
Here is the full stack trace:
at com.esri.arcgis.discovery.admin.SiteManager.exportSite(SiteManager.java:5714)
at com.esri.arcgis.discovery.admin.rest.site.SiteServlet.operationExportSite(SiteServlet.java:430)
at com.esri.arcgis.discovery.admin.rest.site.SiteServlet.service(SiteServlet.java:301)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.catalina.filters.HttpHeaderSecurityFilter.doFilter(HttpHeaderSecurityFilter.java:126)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:712)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:459)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:352)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:312)
at com.esri.arcgis.discovery.admin.rest.DispatcherServlet.service(DispatcherServlet.java:191)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at com.esri.arcgis.discovery.admin.rest.filters.CSRFFilter.doFilter(CSRFFilter.java:113)
at com.esri.arcgis.discovery.admin.rest.filters.OutputFormatterFilter.doFilter(OutputFormatterFilter.java:87)
at com.esri.arcgis.discovery.admin.rest.filters.ErrorFilter.doFilter(ErrorFilter.java:81)
at com.esri.arcgis.discovery.admin.rest.filters.AdminFilter.doFilter(AdminFilter.java:68)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:200)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:607)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:408)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:834)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1415)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Unknown Source) ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I also tried to use a Azure Blob as the Backup location if that's relevant.
JonathanQuinn
by Anonymous User
Not applicable
Thank you! Do you know if the bug is resolved in version 10.8?
JonathanQuinn
It's fixed at 10.8.1.
