Web Adaptor 10.2.2
5610
6
09-22-2015 07:57 AM
CharlesFail
For reasons unknown, one of my web adaptors "lost" its connection to ArcGIS Server - even though the Server Manager still showed an entry for it.
My only resolution was to delete the registration from ArcGIS Server then and re-register the adaptor.
I was curious if anyone else has seen this happen and, if so, any ideas as to what caused it?
We've been running the current configuration since March with no other problems.
Thanks!
UjjwalNigam
Does anyone know if this WebAdaptor bug has been resolved at 10.4 or beyond?
ThomasColson
Not at 10.4, and no plans to (who installs the .x.x.0 version?), but re-registering the Web Adapter has become a regular occurrence for me.
UjjwalNigam
Have you checked if the *ArcGISWebAdaptorAppPool *has read/write access to
the web adaptor config?
There's a bug with web adaptor -
http://support.esri.com/en/bugs/nimbus/TklNMDgxNzM0
ThomasColson
Yes. If that permission issue was the case here, than the problem would be permanent. This is randomly, and intermittently occurring. For no reason, and always happens when there have been no configuration changes.
UjjwalNigam
Yes, this random unregistering of the web adaptor is also a bug...I guess
web adaptor software is full of bugs.
Sent from Gmail mobile on Google Nexus 6
JonathanQuinn
Esri Notable Contributor
Looks like this is resolved at 10.3:
http://downloads.esri.com/support/downloads/other_/103-IssuesAddressedList.pdf
BUG-000083324 - ArcGIS Web Adaptor unexpectedly unregisters or loses its configuration and resets to the default or blank configuration
