Viewing the Server Manager
1376
11-14-2013 08:49 AM
KennethLyons
I'm attempting to publush/update services to a GIS server that i have been using for several years.  Recently when I attempt to do so, the page does not open correctly, or should I say, to it's full extent (see image).  I'm using IE9 and do not have permissions to use other web browsers.
Can anyone help me figure out the issue I'm having and how to go about fixing it?
Thank you
JonathanQuinn
Esri Notable Contributor
Try to enable the compatibility mode on your browser, (the broken page icon next to the certificate error).
RandallWilliams
This is a problem with internet explorer enhanced security configuration. It will go away if you disable that feature. http://blogs.technet.com/b/chenley/archive/2011/03/10/how-to-turn-off-ie-esc.aspx
