Using Raster As Ground Surface
453
02-25-2026 06:45 AM
CRP00
Hello, I have a large (30gb) merged raster with elevation values I want to use as a ground surface in Enterprise web scenes. Unfortunately, I do not have access to an image service/server and have not found a suitable workaround for publishing. Does anyone have any suggestions? If so, what are the options/settings?
Thanks!
GlenterpriseUK
Hi @CRP00,
You can still attempt to publish your DEM as a Hosted elevation layer using ArcGIS Pro.
Have you attempted that?
Regards,
Glen
GlenterpriseUK
Hi @CRP00,
Regards,
Glen
CRP00
Hello,
Thank you! Yes, I ended up going this route. I should have articulated my issue more clearly. I was looking for a way to publish the raster through a more manageable format such as a mosaic; however, a lot of those options are not available unless you have image server I believe.
