Using Cloud builder for azure to create single machine deployment
800
03-31-2019 06:40 AM
ModyBuchbinder
Hello all
I need to demo GeoEvent. For this I would like to create a single machine in Azure that have the Enterprise and the GeoEvent role (and maybe Image server too).
Is there a way to do it using the cloud builder?
If I use the first option (ArcGIS Enterprise) can I create the GeoEvent too?
If I create an Enterprise can I use the builder to create GeoEvent Server on the same machine?
running on the options (and reading the help) for each menu option I do not see a place to put a GeoEvent server license When I use the first option in the cloud builder form and I do not see the option to give portal license when I use the GeoEvent option in the cloud builder.
ModyBuchbinder
Hi All
I checked with Esri and the cloud builder does not support single machine with Enterprise and GeoEvent.
You can build two machines or install Enterprise and add the GeoEvent manually.
Have Fun
