Using ArcGIS Server SSL via the Web Adaptor on a Server that already has SSL enabled.
890
06-03-2013 09:48 AM
TylerGundberg
I have installed the web adaptor on one of our web servers so as to expose AGS service externally. This web server already has SSL enabled on it.
I want to enable SSL on the AGS Server. And have followed the instructions listed here,
http://resources.arcgis.com/en/help/main/10.1/index.html#/Enabling_SSL_using_a_new_CA_signed_certifi...
I want to access the service externally so I used the same �??Fully qualified domain name�?� (FQDN) which that web adaptor is installed on as the �??Common Name�?�.
The problem is my IT group, which get the SSL certificates, are not willing to do so because we already have a SSL certificate issued and installed using that FQDN.
They believe that doing so might cause the existing certificate to become invalid.
Is this the case?
If so, what should I use as the FQDN when creating the new certificate?
-Tyler
