Trouble making direct connection to SQL server 2012 instance/database
4304
05-31-2013 08:54 AM
HenryGlick
I am very new to ArcGIS for Server, but am working on setting up a basic enterprise system using Arc 10.1, IIS, and SQL Server 2012, where the SQL software is on a separate computer from the ArcGIS for Server and IIS software. I am having trouble making a direct connection to my SQL database from a remote client computer because I can't get access to the specific instance that has been established. When I make a database connection from ArcCatalog on a client computer, I am able to connect to SQL Server and gain access to the "ReportServer" and ReportServer TempDB" databases, but when I try to connect to the specific instance (e.g. <servername\instancename>) I get an error that it is unable to connect. When I check the "sdedc_SQL Server" file in the Temp folder, the log reads:
IDBInitialize::Initialize Failed
CAN"T OPEN INSTANCE: sde:sqlserver.
Spatial Engine Connection Failed (-409).
Cannot Get Access to Instance see:sqlserver
I am able to connect to the specific instance and the database of interest from within ArcCatalog on the computer that houses SQL Server 2012, suggesting that this is just a matter of setting the proper permissions for the instance. I have all the permissions set and ports open that I know of or could find info on, but no luck. Is anyone able to provide guidance on how to resolve this? Any suggestions are welcome.
Many thanks!
HenryGlick
Problem resolved.
After two days I figured out that there are two instances of SQL Server running on my data computer, and that the program was defaulting to an instance that I had not created a database in. After creating a database in the second instance, remote client connections worked fine.
