Upgrade of ArcGIS Server 10.9.1 to 11.2 fails
5845
11
02-11-2024 05:58 PM
Brian_Wilson
Honored Contributor
Suggestion solicited on how to actually make a Server upgrade work 10.9.1 to 11.2
Another failed Esri upgrade. This happens each time I do an upgrade. It's something new each time, keeps me on my toes. I have to work past all the bugs in the installers. Usually several. Usually I can refer to my notes for some of them, because they were not fixed in the intervening years. (Why would Esri fix old bugs when they are busy adding new ones??)
The upgrade of Portal and Portal Web Adaptor worked with only one major bug; "the username is longer than 20 characters". But I worked around that.
I then moved on with Server and it ran fine, finished, and launched the web browser. I can't go further than that because it fails to connect on port 6443. It's supposed to connect at https://localhost:6443/arcgis/manager/
I tried various and sundry URL's including localhost and hostname and various browsers including Firefox, Edge and Chrome. I tried connecting over the network from my desktop. (All behind a firewall and there are no reachability problems)
I checked logs and Event Viewer and I see no errors. The regular logs show nothing -- log messages show up in C:\Program Files\ArcGIS\Server\usr\logs\ instead of C:\arcgisserver\logs\ and I think that's what happens until the upgrade completes?  Here is a boring sample
<Msg time="2024-02-11T16:56:33,616" type="INFO" code="7720" source="Server" process="1224" thread="1" methodName="" machine="CC-GISSERVER.CLATSOP.CO.CLATSOP.OR.US" user="" elapsed="" requestID="">The cloud regions configuration file was deleted from this server machine. If you have other server machines in the site, please make sure that the file has been deleted from them as well.</Msg>
<Msg time="2024-02-11T16:56:49,987" type="INFO" code="9011" source="Rest" process="4420" thread="1" methodName="" machine="CC-GISSERVER.CLATSOP.CO.CLATSOP.OR.US" user="" elapsed="" requestID="">Application initialized.</Msg>
<Msg time="2024-02-11T16:56:50,592" type="INFO" code="30204" source="Admin" process="4420" thread="1" methodName="" machine="CC-GISSERVER.CLATSOP.CO.CLATSOP.OR.US" user="" elapsed="" requestID="">Webhook log: Webhooks app context initializing..</Msg>
<Msg time="2024-02-11T16:56:50,594" type="INFO" code="30204" source="Admin" process="4420" thread="1" methodName="" machine="CC-GISSERVER.CLATSOP.CO.CLATSOP.OR.US" user="" elapsed="" requestID="">Webhook log: Webhook processors initialization in progress...</Msg>
<Msg time="2024-02-11T16:56:50,594" type="INFO" code="30204" source="Admin" process="4420" thread="1" methodName="" machine="CC-GISSERVER.CLATSOP.CO.CLATSOP.OR.US" user="" elapsed="" requestID="">Webhook log: Starting webhook processors....</Msg>
<Msg time="2024-02-11T16:56:52,333" type="INFO" code="7702" source="Server" process="1224" thread="1" methodName="" machine="CC-GISSERVER.CLATSOP.CO.CLATSOP.OR.US" user="" elapsed="" requestID="">Web server started successfully.</Msg>
I found a suggestion regarding forcing the upgrade by going to https://cc-gisserver.clatsop.co.clatsop.or.us:6443/arcgis/admin/ but this is impossible because there is nothing running on port 6443
That article also mentioned the C:\arcgisserver\config-store\version.json -- it still says 10.9.1 which is depressing.
I tried running "repair" and rebooting. I've rebooted many times. I've tried running under a local account and under the AD network account.
I found a file from 2022 called version.rlock next to the version.json file and deleted it and then ran the installer again. The repair option wont run again.
I am thinking the actual upgrade does not happen until the URL is invoked?
I peeked at the Tomcat logs which as always show "potential memory leak" messages but nothing jumps out.
I will now tell my admin that he needs to roll back to the snapshots he made this morning, so that we can function normally rolling back to 10.9.1, having basically wasted another day. A Sunday. Insert more colorful language here.
Brian_Wilson
Honored Contributor
I had my fabulous IT guy clone the Server VM so I could hack away on it. I was able to get a version of 11.2 installed there, from scratch. It worked fine, but, no data.
Then I went ahead and did the full upgrade this past weekend. Hit the same problem, nothing on port 6443. Knowing it's a Tomcat app, I searched the Tomcat conf files and found that some text was different between the upgraded and installed-from-scratch versions in server.xml
Using 'netstat' in a Powershell I could see there was just no service running on port 6443. The service on 6080 simply redirects to 6443 at which time a browser just returns an error.
ESRI version from upgrade (fails)
<Connector SSLEnabled="true" URIEncoding="ISO-8859-1" clientAuth="false"
 connectionTimeout="60000" connectionUploadTimeout="1000000"
 disableUploadTimeout="false" maxHttpHeaderSize="65535" maxPostSize="10485760"
 maxThreads="150" port="6443"
 protocol="org.apache.coyote.http11.Http11Nio2Protocol" relaxedQueryChars=""
 scheme="https" secure="true" server=" " sslProtocol="TLS"
 useServerCipherSuitesOrder="true"/>
My current version from fresh install
 ciphers="TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,
 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA,
 TLS_DHE_RSA_WITH_AES_256_GCM_SHA384, TLS_DHE_RSA_WITH_AES_256_CBC_SHA256,
 TLS_DHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_256_GCM_SHA384,
 TLS_RSA_WITH_AES_256_CBC_SHA256, TLS_RSA_WITH_AES_256_CBC_SHA,
 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,
 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_DHE_RSA_WITH_AES_128_GCM_SHA256,
 TLS_DHE_RSA_WITH_AES_128_CBC_SHA256, TLS_DHE_RSA_WITH_AES_128_CBC_SHA,
 TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA256,
 TLS_RSA_WITH_AES_128_CBC_SHA" clientAuth="false" connectionTimeout="60000"
 connectionUploadTimeout="10000000" disableUploadTimeout="false"
 keyAlias="SelfSignedCertificate"
 keystoreFile="C:\Program Files\ArcGIS\Server\framework\etc\certificates\arcgis.keystore"
 keystorePass="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
 maxHttpHeaderSize="65535" maxPostSize="10485760" maxThreads="150" port="6443"
 sslEnabledProtocols="TLSv1.2,TLSv1.1,TLSv1" sslProtocol="TLS"
I saw references to a keystore file in the working version, so I confirmed the file existed. I edited the server.xml file to replace the lines above and restarted the service and it worked. I was then able to complete the upgrade with only the usual hiccups and flaws.
Once it completed I checked services and maps and all and everything seems to be working so far. It's been quiet today. Huge anticlimax. The only discernible difference so far is the version number.
vipulsoni
Hi @Brian_Wilson ,
Thanks for this post and the solution posted, last weekend during the upgrade of ArcGIS Portal Server (federated), unfortunately we also faced a similar situation. The ArcGIS Server webpage for post installation did not load.
Upon investigation and searching the Esri community forums I landed upon your post. Started to try fixing by searching the logs as you mentioned. I did not have the IT guys to help me since they were busy with scheduled work, instead I copied SSL files from another ArcGIS server (different hostname) and updated the Tomcat Server.xml and restarted the ArcGIS Server service and then tried opening the URL of the Manager. it loaded up and automatically started the Post Install Upgrade process. The Post install upgrade completed successfully but then the ArcGIS Manager interface was behaving weird due to the copied ssl (i believe). then, I opened the ArcGIS Admin page and updated the Machine > SSL with the CA Signed SSL .PFX File (replacing self-signed ssl) and restarted ArcGIS Server Service which then loaded the Manager and all was Ok. Many Thanks to you and your solution post.
