Unable to register or validate DB, FDO error: -2147209112, Invalid xml registry file c:\program files\arcgis\server\framework\..\XmlSupport.dat
840
02-04-2021 11:07 AM
Taladi
New Contributor III
Hi All,
Unable to register or validate a DB in ArcGIS Server Manager. Server SEVERE Logs are as below.
01. The connection property set was missing a required property or the property value was unrecognized.
FDO error: -2147209112 Unable to instantiate class for xml schema type: DEWorkspace
02. Invalid xml registry file: c:\program files\arcgis\server\framework\runtime\arcgis\bin\XmlSupport.dat
ArcGIS Enterprise 10.8.1, Multi-machine Deployment, Server in S1, Portal in S2, Data Store & RDBMS in S3.
Any suggestions Please.
George_Thompson
Esri Frequent Contributor
What is the RDBMS being used?
Can you view data in the DB within ArcGIS Pro?
What sort of authentication is being used; O/S or DB?
--- George T.
Taladi
New Contributor III
Hi George,
Thanks for the quick response.
RDBMS is SQL SERVER 2016
Yes, I can view the data in ArcMap & Pro
DB Authenticiation in use.
Regards,
Venkat
