Unable to connect to arcgis server manager
1115
06-20-2017 12:33 PM
ShannonBailey
I recently installed ArcGIS server 10.5 for Linux. I went through the setup and install wizard. I started the server via the script arcgisserver and I see the following process:
sysadmin 20315     1  0 19:20 ?        00:00:00 /data/arcgis/server//framework/runtime/xvfb/Xvfb/bin/Xvfb :600 -screen 0 1280x1024x24 -ac -xkbdir /data/arcgis/server//framework/runtime/xvfb/Xvfb/share/X11/xkb -dridir /data/arcgis/server/framework/runtime/xvfb/Xvfb/lib/dri -fp /usr/share/X11/fonts/misc
But I get an Unable to connect message when trying to connect to localhost:6080 ?
I disabled the firewall, but I still cannot connect.
JonathanQuinn
Esri Notable Contributor
Do you see any java processes running?  You can try to take a look at the Server logs, but i'm not sure they will report much if you can't connect at all.
