Turn on all pop-ups for map image layer via ArcGIS Online Assistant JSON
1419
01-28-2020 09:02 AM
GeorgiaRoberts1
I am trying to turn on all pop-ups within a map image layer via the item's JSON in the ArcGIS Online Assistant, as this process takes hours manually. I have previously used this methodology for other layers in web maps, however the JSON isn't showing any information regarding pop-ups this time. I am wondering if this functionality is limited to feature services?
AndrewWhitman1
HI Georgia,
I am wondering if the web image layer was not setup using a mosaic data set. Based on the documentation, this is a prerequisite for configuring popups when using imagery.
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups.htm#ESRI_SECTION1_039AEBEB52B5...
If the process of setting up mosaic data sets becomes too tedious, I bet ArcGIS Pro tasks would come in handy:
https://pro.arcgis.com/en/pro-app/help/tasks/create-a-simple-task.htm
Tasks are really helpful at creating efficient workflows that are iterative such as setting up mosaic datasets.
Hope this helps!
