Hi there, I need some help.
I want to publish a trace network service, I have tried creating the trace network and it was working properly, but now I am facing some issues, after executing the "Create Trace Network" tool, when I try to set the starting points, that tool appears "blocked"starting_points.png
That did not happen to me before.
In addition, if use as starting points an already existing shapefile, i find the following error:
And also, i don't know if this last example has anything to do with the previous errors but I cannot edit a new point feature class in the enterprise geodatabase:
Any suggestion??
Thanks in advance
I am not as familiar with the trace network as I am the utility network, but I think they have the same restrictions. You must publish the trace network to a feature service to trace and edit once versioned.
Hi Mike, some questions if you don't mind:
- What you mean is that once versioned, I cannot use the trace tool in ArcGIS Pro?
- After publishing (I have already done it as WebLayer) how and where am I able to use the trace tool? or in your case, the utility network?
Im quite new to this
Thanks mate!
You need to publish a feature service and create a map from that. https://pro.arcgis.com/en/pro-app/latest/help/data/trace-network/publish-and-consume-services-with-a...
