Token-based authentication failure provided in the Collector App
2237
09-24-2019 09:44 PM
HankYang
Hello all,
I really appreciate your time in advance. The token-based authentication failure was displayed from the Logs from the Esri Collector App when I tried to make the offline map. I feel this issue may come from the recently installation of federated server and hosting server with the Portal. Before the setup of the federated and hosting server in the Portal, the creation of offline map was working in the Collector.
The “0924TestCampsite” is from the REST service hosted on our own ArcGIS for Server (it is a versioned feature class with the GlobalID). In addition, I have tried to make the offline map in different places (different wifi). However, I get the same error listed below.
It would be appreciated for your opinions.
Hank
Patches installed in the server
Inbound Rules within the firewall with the server
The inBound rules include the ports such as 7443 and 7080
Machine name: stw-geogstateparks.ad.okstate.edu
Machine Environment:
One machine has these software packages installed
Server for ArcGIS 10.31 Web Adaptor
ArcGIS for Server 10.31
Portal for ArcGIS 10.3.1
Windows Server 2012 R2 Datacenter
IIS Web Server 8.0
ArcGIS Data Store 10.31
Collector for ArcGIS Version: 19.1.0
Build 2666
IOS mobile devices
NickG
Hi Hank,
I know it's been a while but did you ever figure this out? I am experiencing a similar issue.  Thanks in advance for your help.
