Tiled Service Project Issue
2653
07-02-2015 06:50 AM
ArjunDongre
I have not worked with Tiled Services much. I have successfully created and added a tiled service layer with a custom tiling scheme, however the projection I specified did not get applied to the service. It defaulted to 102719.The projection is incorrect when I check the REST endpoint. It leads to projection problems when manipulating the map in my map. How do I fix this?
Arjun
Tags (1)
thejuskambi
You should probably ask this question in a different form.
Well, there are couple of place you could start looking into.
  • Check the projection system in the map document used to create the service.
  • The projection system used to create the tile schema
In general review all the projection system carefully.
