This site is inaccessible localhost does not allow connection.ARCGIS SERVER MANAGER
5068
02-20-2024 06:52 AM
Serigne_MomarThiam
Can someone  help me i am having some difficulty upgrading my ArcGIS SERVER from 10.9.1 to 11.2 when i finished licencing the web page to configure and upgrade manager showed me this error localhost does not authorize the connection
JoshuaBixby
MVP Esteemed Contributor
It may be ArcGIS Server isn't listening anymore on the non-TLS port 6080, try an HTTPS connection on 6443.
Serigne_MomarThiam
Hi JoshuaBixby,
Thanks for your responsed but i try this solution there ar the same error
HenryLindemann
@Serigne_MomarThiam , are you seeing ArcSOC.exe in task manager if not then your server might be down, otherwise just have a look if you have a proxy configured and add the https://yoururl:6443/arcgis as a exception
Regards
Henry
ReeseFacendini
Esri Alum
It looks like it could be a corrupted server.xml file, which means the internal web server of ArcGIS Server no longer understands how to listen for web traffic over 6443 (and 6080 also fails). Take a look at this support article for details on how to fix the corruption issue https://support.esri.com/en-us/knowledge-base/how-to-fix-an-arcgis-keystore-or-server-xml-corruption...
DavidColey
MVP Frequent Contributor
You should also maybe check that the install actually created or re-created the windows service ArcGISServer.exe . . .  my upgrade from 11.1 to 11.2 attempt did not do so on our Windows Server 2016 platform.
https://community.esri.com/t5/arcgis-enterprise-questions/arcserver-hosting-site-11-2-won-t-create-t...
We are using this as an opportunity to move to Windows Server 2022 for our deployment before attempting the upgrade again.
