The server returns an empty result
2835
09-01-2015 12:58 AM
BastianZimmer
Dear all,
A (Model Builder) tool has been set up as a geoprocessing service on the server. The tool consists of Python scripts and native Model Builder functions. Unfortunately, I did not write this tool but it has to set up on the server. Furthermore, I have never worked with ArcGIS Server before and am glad of any help. In short, top conditions. (:
I have started the tool locally and then uploaded it via *Geoprocessing -> Results -> Share as Geoprocessing*. Local the tool works and writes the desired line in the table. A required parameter is GPFeatureRecordSetLayer a simple esriGeometryPoint.
If the tool is started with the submitJob() function, then I get an empty result. Furthermore, I receive no errors or warnings.
What could be the problem?
Are the Python scripts flawed?
Must the Skripe be complemented so that a result is returned?
The server must be adapted so that a table can be returned?
Best regards
