System Designer Workflows and Mapping to Applications
2578
03-05-2013 07:04 AM
LorneDmitruk
I've been doing a some work with the System Designer tool and I was wondering if it's possible to map a workflow to more than one application. For example I have a workflow that draws an image from an image service. I would like to use this workflow in several applications. As near as I can tell it appears you only map one workflow to one one application indicating the workflow would have to be copied and renamed for each application I would to use it in. Is my assumption correct?
Cheers!
WaelYahya
You mean operation to workflow mapping ...
Please send the steps with screenshots if possible ....
LorneDmitruk
Here's what I'm trying to do, I have a couple of existing applications as shown below:
[ATTACH=CONFIG]22404[/ATTACH]
And the existing operations workflow and operation
[ATTACH=CONFIG]22405[/ATTACH]
Here's the current workflow operation to software service association
[ATTACH=CONFIG]22406[/ATTACH]
So the View imagery operation is mapped to the google earth application.
What I would like to be able to do is map the view imagery operation to the pipe access web application in addition to the google earth application. However when I access the pipe access web software service with the view pipeline imagery operation the operation to software service map shows the google earth mapping.
[ATTACH=CONFIG]22407[/ATTACH]
So I'm not sure how to proceed at this point. Can I just add the pipe access web to the operation as below and would it be a valid configuration?
[ATTACH=CONFIG]22409[/ATTACH]
Or do I have create a new workflow with the appropriate operations for pipe access web?
