Sync excel edits to enterprise?
1072
07-20-2017 08:20 AM
JuliaGerdes1
Is it possible to link an excel spreadsheet, that is frequently updated, to a feature class related table in sde? How can I auto-sync frequent edits in an excel table that is connected to a related table and feature class in enterprise? Thanks!
JonathanQuinn
Esri Notable Contributor
This will likely need to be done through some scripting or other third party tools.  This thread goes into some techniques:
https://community.esri.com/thread/65177
ThomasColson
Not entirely possible......you wouldn't be able to add rows to the excel table as you'd have to also figure out how to add a new objectid to each row.....which you could do if you were calling the SP that fired the new OID generation. This would be easier if you created a new table in SQL as the "back-end" for your excel table, and used triggers or SP's to accomplish the marriage with your SDE table.
