Symbolize Polyline Feature based on Point Feature Values Logic If Statements
581
05-12-2021 07:26 AM
GentryEwing1
I have GeoEvent grabbing real-time status for point layer features. I am trying to develop a workflow that will give a related Polyline Feature a status based on the point layer features. I want this to be displayed in a WebMap or Dashboard I already have created.
Example:
Point A - Status = 0
Point B - Status = 1
Point C  Status = 0
Polyline A - Status = 1
Polyline B - Status = 0
I believe I can use IF statements to write code that has rules assigned to it that will change the status of the Polyline features based on those rules.
If Point A = 0, and Point B = 1 and Point C = 0, then Polyline A = 1
If Point A = 1, and Point B = 1 and Point C = 0, then Polyline A = 0
If Point A = 0, and Point B = 1 and Point C = 1, then Polyline A = 0
To my knowledge, ESRI does not support symbolizing layers based on ARCADE in the popups.  Any direction/help would be much appreciated.
VictorTey
You double posted 🙂
Hi, you can build/use a view to achieve what you want.  View can be created from pro or from sql.
select case
    when Point A = 0, and Point B = 1 and Point C = 0 THEN Polyline A = 1
    WHEN Point A = 1, and Point B = 1 and Point C = 0 THEN Polyline A = 0
    ELSE Polyline A = 1
END as status,
attribute1,
   attribute2,
from table a inner join table b on a.id = b.id
