Story Map Journal section limit?
1277
09-10-2019 12:49 PM
RoseZhou2
Hello,
In Enterprise Portal, is there a number limit to the Map Journal pages/sections? After 30 sections, I couldn't add any more sections.
Any help is greatly appreciated.
Rose
Tags (1)
RachelSears
Hi Rose,
I just tested it on my Portal and was able to add more than 30 sections to my Map Journal. I know that the Side Panel layout has better performance than the Floating Panel for journals that have more than 20 sections, but I was still able to add 30 sections with the Floating Panel.
What kind of content does your story map contain? Which version of Portal are you using?
-- Rachel
RoseZhou2
I changed the “MAX_NB_SECTIONS” from 101 to 200 in the “config.js” file in “...Portal\apps\MapJournal\app” folder. Now I can add more sections. Not sure how it counted. After I added 30 sections, I could not add more before.
Rose
