SQL Views Pop Ups, Queries, & Table Viewing
1213
12-18-2023 11:20 AM
CameronLacelle
I am wondering if and when it will be possible to have pop-ups for SQL views in ArcGIS Enterprise (in Map Viewer and associated applications). A lot of our data is in SQL and particularly our infrastructure data, which is updated frequently with inspections from other departments in our organization, is in a SQL view. Right now, when I add the data to my map in my Experience Builder Application, I am able to visualize the data fine and symbolize it how I would like. However, I cannot see pop-ups when clicking the points, I cannot view the table from an attribute table widget in Experience Builder, and I can query the data but it won't display the results from the query, and will only say how many features resulted from the query (i.e. 345 out of 1745 total).
TanuHoque
@CameronLacelle
can you pls check and see if the issue that you are running into is similar if not same as the following bug:
https://support.esri.com/en-us/bug/unable-to-query-the-map-service-from-the-rest-endpoint-bug-000156...
