SQL database date and Enterprise date don't match
1892
01-05-2022 09:54 AM
by Anonymous User
Not applicable
Hello,
We are having issues with the date/time.  We have date time coming from a sql database/geodatabase and when we open the data in the Enterprise that date/times do not match.  This is from SQL
AnnettePoole1_0-1641405126774.png   for example, the middle date 2020-01-02 02:43:00.000 translates to 1/1/2020, 6:43 pm.
AnnettePoole1_1-1641405216865.pngThis is the enterprise date.
As you can see the date and time change.  Does anyone have an idea how to fix this? Thank you.
Annette
NeumanAndrew
It's most likely that your SQL Server is using your default time zone and your Enterprise is configured to use GMT which is the default for web services. We ran into this issue when we first start using Collector to capture data in the field and the times didn't align when I imported the data into a different SQL server database.
TanuHoque
@Anonymous User
Please check the Time Zone property for the service in the Manager site, and make sure it is set.
also, check out this tech session discussion how date/time values are worked across our platform.
https://www.youtube.com/watch?v=esb8X-1TtPk
This video demonstrates how data containing dates and times are handled and represented in ArcGIS. You will learn best practices for sharing date-time data as map and feature services. You will also learn how date-time data is presented when using it in the ArcGIS Enterprise and ArcGIS Online Map
NeumanAndrew
