Specify Temp Directory
779
03-05-2014 08:45 AM
MichaelWilkerson
We're using ArcGIS 10.2 on RHEL Linux 6.
When deploying a new service the ArcGIS server currently uses the /tmp directory as it caches the file for processing.
Is it possible to specify a different temp directory?  Perhaps either by providing an additional JVM parameter in the agsserver.sh file or using environment variables?
So far the only reference to changing the temp directory is during installation by setting an IATEMPDIR environment variable.  Doesn't seem to modify default behavior once the server is up and running and processing new services for deployment.
Michael
