SOE Property Page not found during deployment
2013
06-05-2013 01:45 PM
SimonLeo
I developed and deployed a SOE. it works fine. There are several parameters I want to make it configurable by the Admin, so assume a property page is necessary.
based on this sample, I customized it into my own then re-built SOE solution. (.NET 3.5)
however, when I was trying to deploy this newer version, the AGS manager always says 'Property pages not found'. for now, the page(html) and template(JS) file are located under project_root_path\resources\SOE_Namespace_Name\SOE_Assembly_Name folder, which is the structure in that sample.
I am only trying to enable property page in AGS manager site, not in Desktop.
could anyone point me to the correct direction? thanks!!
julienlesbegueries
I've got the same issue. Did you finally succeed in deploying an SOE with custom defined properties?
Best,
Julien.
