Sharing 3D Tile Cache Data Store: Problem Submitting tile caching job
6562
9
07-29-2022 09:16 AM
CW-GIS
Setup a Tile Cache Data Store through Azure Cloudbuilder. Installation succeeded with no errors.
When trying to share a 3D layer from ArcGIS Pro, I get the following error: Problem Submitting tile caching job
On the log the last lines are:
  • Status: InProgress StatusMessage: Initializing scene caching process on the server
  • Status: Failed StatusMessage: Problem submitting tile caching job
MatthewThomas2
Hi Jeff, try logging into ArcGIS Server Manager and under Services > System, try restarting the CachingTools service and the PublishingTools service. If that doesn't fix it, try logging into the ArcGIS Server Admin endpoint, and go to Services > System, and open each of these 4 services and restart them all: CachingTools, CachingToolsEx, PublishingTools, PublishingToolsEx. Then try publishing again.
CW-GIS
I didn't see CachingToolsEx or PublishingToolsEx, but I saw CachingTools10x & PublishingTools10x (picture attached). I restarted all the services and tried it again and got the following error:
Error - ERROR 160213: A networking error occurred.
Error - Failed to execute (Manage Scene Cache).
Informative - Failed at Monday, August 1, 2022 10:21:25 AM (Elapsed Time: 12.35 seconds)
Error - Failed.
MatthewThomas2
Jeff, what version of ArcGIS Enterprise and ArcGIS Pro are you using?
CW-GIS
Enterprise is 10.9.1 & Pro is 2.9.0
I did see the Feature Layer & Scene Layer were uploaded, but when I try to add it to a scene it says:
"Scene service is missing root node."
CW-GIS
Hey Matthew,
Just curious if you had any ideas about how to solve this? We still haven't figured it out
CW-GIS
Solution: We needed to open up inbound ports 29080 & 29081 on the tile cache machine.
ALESSANDRASPREAFICO
Hi all,
I have a similar problem.
When I share a web layer on ArcGIS Enterprise I get the error message Problem Submitting tile caching job
I checked and I already have the ports 29080 & 29081 open.
I restarted the CachingTools service and the PublishingTools service from ArcGIS Server Manager.
Theis didn't solve the issue.
I checked on ArcGIS Server Administrator and in the list I don't see any CachingToolsEx & PublishingToolsEx nor CachingTools10x & PublishingTools10x.
Attched there's my list
Do you have any ideas about what's wrong?
Thank you!
CW-GIS
I still have the issue when trying to share 3D content greater than ~50MB (if I remember right).
I had a ticket in with esri like a year ago, but they just kept asking me to do basic stuff like clear my browser cache, nothing ever got solved.
ALESSANDRASPREAFICO
I solved the issue I had when sharing as web layer.
I had to change the URL of the server, I federated the server with a wrong URL.
I missed to install the datastore for tile cache, so I did it.
Plus I substituted the self-signed SSL certificate with a CA SSL certificate. I had to change it in many places: IIS, datastore, portal and server.
I hope this can help, but not sure.
I believe (but not sure) that your error is due to something different.
