Share Service hangs
1058
06-27-2013 09:26 AM
TimHayes
Since March this year, maybe after the last Microsoft Windows Update, every time I go into ArcMap - Share As Service - Overwrite Existing Service it works sometimes, other times it just hangs at one or other dialog box and does not do anything.
I had no problem doing updates to my Services before March or so, took about 5 min per service. Now, I need to force ArcGIS Desktop to close, re-open it, Share Service over and over again, eventually it does work, but now it takes on average 30 min to 1 hour to Share As Service - Overwrite Existing Service.
Same thing happens when I share a new service and do not do overwrite.
I made no changes to our ArcGIS Server 10.1, SDE, and Desktop, and SQL Server Express 2008 R2 configs.
Would this problem be fixed if I upgrade to 10.1 SP1?
Is anyone else experiencing this same problem?
Any idea why this happening? it is making my work extremely difficult.
KevinHibma
Sometime shortly after the User Conference (July):
http://www.esri.com/software/arcgis/whats-coming
TimHayes
My apologies, I already posted on this issue in May. ESRI provided an answer:
http://forums.arcgis.com/threads/84239-Method-failed.HRESULT-0x80070057-The-parameter-is-incorrect.-....
When will 10.2 be released?
KevinHibma
