Server SOAP API - Add RECORD to table in SDE
1874
05-03-2013 01:43 PM
MichaelRobb
Honored Contributor
I miss the Context server, ArcObjects in 9.3...
There are Zero examples of Feature Service SOAP.
Delete was easy...
Add is a different story...
I am talking about this:
http://resources.arcgis.com/en/help/soap/10.1/index.html#/Add/01vp0000007v000000/
I have no idea how to get this to work...
Ideas?
I know if this was a FEATURE, i would then use  ESRI.ArcGIS.SOAP.GraphicFeature(), but this is a record for a table that is accessible through a feature service.
I am able to get a PropertySet.propertyarray but what to do with it... to get it to a pDataObjects.
  Dim CatalogServiceProxy As New ESRI.ArcGIS.SOAP.ServiceCatalogProxy
        CatalogServiceProxy.Url = CatalogServiceURL
        'If CatalogServiceProxy.RequiresTokens() = True Then
        '    Dim ArcToken As New ArcServerToken(CatalogServiceURL, UserID, Password)
        '    Token = ArcToken.GetToken()
        'End If
        Dim FeatureServiceProxy As New ESRI.ArcGIS.SOAP.FeatureServerProxy
        'FeatureServiceProxy.Url = FeatureServiceURL + "token=" + myToken
        Dim inputfields As ESRI.ArcGIS.SOAP.PropertySetProperty() = New ESRI.ArcGIS.SOAP.PropertySetProperty(2) {} ' There are TWO Fields / values
        Dim pPropertySet As New ESRI.ArcGIS.SOAP.PropertySet
        Dim pDataObjects As New ESRI.ArcGIS.SOAP.DataObjects
  Dim pPropertySetPropertyLINCNumber As New ESRI.ArcGIS.SOAP.PropertySetProperty
            Dim pPropertySetPropertyTrackStatusID As New ESRI.ArcGIS.SOAP.PropertySetProperty
  pPropertySetPropertyTrackStatusID.Key = adofields.name
                        pPropertySetPropertyTrackStatusID.Value = "Some value"
 inputfields.SetValue(pPropertySetPropertyTrackStatusID, 0)
            inputfields.SetValue(pPropertySetPropertyLINCNumber, 1)
            pPropertySet.PropertyArray = inputfields
******* WHAT TO PUT HERE *******
'Store the array, ignore the result at this time.
            Dim Result As ESRI.ArcGIS.SOAP.EditResult() = FeatureServiceProxy.Add(1, pDataObjects, Nothing, True, False)
