Search Widget in Experience Builder
3028
05-26-2022 09:32 AM
RichardCreek
I saw that the September 2021 Experience Builder update contained new functionality, including a search widget; however, I'm unable to find the search widget. I've included a screenshot of my Experience Builder window for reference. I believe we are not running the developer edition if that makes any difference.
jcarlson
The Enterprise version of EB only gets updated when the portal does. You'll need to use the dev version if you want the latest widgets, otherwise you'll have to wait for the next Portal version.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
RichardCreek
Thanks for the quick response, this helps.
AngelaSchirck
So,  we are moving over to enterprise and I was having the same problem.  I'm sure, since we just implemented enterprise 2 weeks ago, that we have the latest version (I see this post was in May of this year).  I wanted to add a search widget to my map, which was available on AGOL, but it doesn't seem to be available in enterprise.  See below:
There seem to be a lot fewer widgets in enterprise.  Does anyone know why this widget isn't available? You would think that "search" would be a basic widget that would come out in the first build.
