SDE Table Registry
5026
01-21-2013 11:22 AM
MatthewStarr
Greetings,
I have a geometric network (junctions) that seems to be stuck in the sde.table_registry.   This is keeping me from using the same name of the geometric network which I have since deleted.  the new network must have the same name based on various customizations and other schedulded tasks.
steps I performed
1aDelete all versions, compress
1b. delete geometric nework
2 disable archiving
3 unregister as versioned
4 recreate geometric network...  error  [ORA-20218: Registration 11116 already exists][TABLEOWNER.GasNetwork_junctions]
the SDE geodatabase on Oracle 11g
The featuredataset in which this geometric network had existed did have archiving enabled so the geometricnetwork_junctions_H table is also stuck in the registry.  If I run the command:
          sdetable -o describe_reg -U tableowner ....
these two tables are listed in the sde registry.  However when I run
         sdetable -o describe_reg -t tablename.....
these two tables are not found.
How do I remove the registry entries?
I have recreated a geometric network with a different name so I am convinced this is the problem.
Thanks in advance
Matt Starr
MatthewStarr
Greetings,
steps I performed
2 disable archiving
Thanks in advance
Matt Starr
I am answering my own post.
I called SDE support and the order should have been to:
Disable archiving
unregister as versioned,
delete the geometric network.
I was helped to get rid ot Items in the registry and child items in other tables as well.
