SDE layer not published as Feature Layer when using Branch Versioning + Archiving + Relationship Class
446
05-15-2026 12:01 PM
GeomatiqueVMR
I have a map service published from ArcGIS Pro to ArcGIS Enterprise 11.1 with Feature Access enabled. My map contains two layers:
  • SDE.arbres (Origin in relationship) → published as both Map Image Layer and Feature Layer
  • SDE.historique (Destination in relationship) → published as Map Image Layer ONLY
Both layers have:
  • Branch versioning enabled
  • Archiving enabled
SDE.historique is the Destination in a One-to-Many Relationship Class with SDE.arbres.
Why is SDE.historique not available as a Feature Layer? Is it related to the Relationship Class (Destination role), the archiving, or both?
Thank you!
Teresa-AZ
Hi there!  I have had this issue in the past (Pro 3.6 and AGE 11.3) using data from a SQL DB, however we use Traditional Versioning.  Anyway, I believe that when you Publish, you MUST check the Feature Layer box so that it creates both a Map Image Layer and a Feature Layer SO you can use it however you like.  If you do not, it will be limited.  I believe it is in the Publish menu in Pro and about halfway down. Sorry I do not have images.
Cheers!
T
