Samba share linux problem
2484
06-06-2013 01:50 AM
Stefanobruscoli
Hello
My config:
- Arcgis Server 10.1 SP1 on SUSE SERVER 11 SP2
- in same server also PostgreSQL 9.05
AGS work fine and I can publish service: mxd in samba share and feature in geoDB on Postgres
I've made registration of folder on server like this:
Publisher folder path = \\myserver\mysharesamba
server folder path= /pathonlinux/mysharesamba
and it is validate from server
The problem:
if I use a .mxd with file geoDB on samba share and I try to publish it I've this error:
"Updating the server data path for layer <layer> failed. Attempted server path was DATABASE= <here is my registrated path>. Please verify that the path exists on the server"
And after:
Failed to create service error: code 404
error executing tools 001487 and 001369
Please can help me?
Thanx
Stefanobruscoli
Solved by Pavel Stepanek employee of ESRI ITALIA:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Common_problems_and_solutions/0155000004qm...
some parameters for samba share!!!
Thanx Pavel
