ESRI ArcGIS Server for the Microsoft .NET Framework
1497
06-12-2013 11:44 PM
HanneDanielsen
I am sorry for disturbing you, but I am totally confused and need help and advice.
I have been told by my boss to look into obtaining a 'ESRI ArcGIS Server for the Microsoft .NET Framework'.
I have normally nothing to do with this.
So I have been looking at internet pages to find a place where I can buy a license for 'ESRI ArcGIS Server for the Microsoft .NET Framework'. I can find many many pages that describe how to install.
But nothing about how to obtain/buy a license.
Is it 'just' a license for ESRI ArcGIS Server     which can then be used in connection with Microsoft .NET Framework.
Or is it a very specific piece of software? Please advise me.
I have a feeling you are not allowed to give prices here in this forum (but it would be nice).
AlexeyTereshenkov
Hanne,
ESRI ArcGIS Server for the Microsoft .NET Framework is a piece of software that is available in version 10.0. You can read more about it here. This is a piece of software you are supposed to buy from a local Esri distributor in your country/state. You can obtain the current prices only from your local Esri distributor. The list of distributors can be seen here.
You will be provided with the Esri customer account which you can use to login into Esri Customer Care portal where you can download all the software you have access to.  Another option of obtaining the software would be ask for a DVD or another media applicable which might be sent to your place. After downloading/receiving and installing the ESRI ArcGIS Server 10.0 for the Microsoft .NET Framework, you would need to license it either by contacting your local Esri distributor customer service or by using the Internet online or via e-mail. Information on what is available in each license level (there is a couple of them) can be found in the functionality matrix here.
HanneDanielsen
SUPER - Thank you so very much.
I don't know if there are point to give in this forum (In many forums there are).
You should have MAx points.
AlexeyTereshenkov
No problem, glad you got it! Sure, there are ways to give points to an answer or mark a post as an answer. Check the description here: http://resources.arcgis.com/en/help/forums-mvp/
