Run Website on AMI?
887
06-16-2014 05:21 AM
BrianHiller
I've successfully deployed ArcGIS Server map and feature services on an ArcGIS 10.2.2 Server with SQL Express AMI, but now I'd like to configure the AMI to run a website and I'm running into difficulties doing so.
I've enabled IIS on the server and can access webpages and documents on the local machine using localhost, however when I try to access the same webpages or documents from an external machine I cannot.
Can someone please tell what I need to configure on the instance to make the webpages externally accessible.
I've tried modifying the instance's security group, and I've looked at various settings on the load balancer, but I'm not sure what I need to change.
Any help would be greatly appreciated.
BrianHiller
