Role Type "User" has no access using windows domain and built-in roles
834
10-08-2012 06:38 AM
GerardoGarcia
When setting up security in server manager to use both windows domain and arcgis server built-in roles, no users are allowed access to services if they are setup as a role type of "User". Both "administrator" and "publisher" work, but not "User". The error returned is:
Error: User does not have permissions to access this folder.
Code: 403
[ATTACH=CONFIG]18249[/ATTACH]
I've setup IIS for windows authentication and disabled everything else. Am I missing something? Or is this a bug. Thanks for any help.
Jerry
GerardoGarcia
So, after doing more research, it seems as if this really is a bug that should be addressed in SP1.
From link
http://downloads.esri.com/support/downloads/other_/189810.1_SP1_Announcement.pdf:
"NIM080829 - Authorization fails if roles are managed in the built-in store and authentication is done by the web adaptor."
Hope this helps anyone who might be having same problem.
HXiao
It seems that this has not been fixed in sp1. I received the same error message in 10.1 sp1. Does anybody have a solution?
