Roads and Highways for Server Extension Authorization
4044
09-11-2014 12:20 PM
JillianStanford
I am attempting to install the Roads and Highways Server Extension for 10.2.2 and am not able to authorize it.
The installer does it's thing and says that the extension was installed successfully. The documentation states: "Use the ArcGIS 10.2.1 for Server Software Authorization Wizard to add the Esri Roads and Highways for Server license feature to your site. The wizard starts after the ArcGIS 10.2.1 for Server installation completes"
The wizard does not start. If I open the Software Authorization wizard myself and attempt to authorize an extension, Roads and Highways is not listed.
When I publish a service the Linear Referencing capability is available. If I choose that capability and publish a service, LRSServer is listed in the REST directory but when I go to access it I get the error message: "Esri Roads and Highways server extension license is not available". Fair enough.
What step am I missing??
Thank you!
Jill
JillianStanford
In case it can help somebody else I will answer my own question.
To authorize the server extension go to the Server Authorization wizard located in Start > All Programs > ArcGIS  > ArcGIS for Server 10.2.2 > Software Authorization.  Select the option that says you want to only authorize extensions and continue to go through the authorization process. Once the extensions pop up, type in "Roads and Highways"
in one of the blank fields, and then put in the authorization number beside it.
The documentation isn't very clear on this but it worked for me!
JillianStanford
