Reusing .ags connection files after Server IP change
282
09-22-2025 12:32 PM
AlinaTaus
We are in the process of moving our ArcGIS Server Test environment to a new machine but we are planning on keeping the same server alias.  I am assuming the existing .ags connection files should still work since they were set up using the server's alias and not the IP address.  Just wondering if this assumption is correct or if anyone has had any issues reusing .ags connection files after a server move.
Thanks!
sxw_eaglegis
Hi there - Yes I can't see any issues with using the same existing .ags connection files if the same server alias/DNS is being used.
