Rest SOE problem
1738
07-19-2012 10:07 AM
YanyiZhang
Hi guys,
    I just start using SOE in ArcGIS Server 10.1 and find something strange here. When I create a RESTSOE project from Visual studio 2010 template, the handler is like this:
        private byte[] SampleOperHandler(NameValueCollection boundVariables,
                                                  JsonObject operationInput,
                                                      string outputFormat,
                                                      string requestProperties,
                                                  out string responseProperties)
            responseProperties = null;
            string parm1Value;
            bool found = operationInput.TryGetString("parm1", out parm1Value);
            if (!found || string.IsNullOrEmpty(parm1Value))
                throw new ArgumentNullException("parm1");
            string parm2Value;
            found = operationInput.TryGetString("parm2", out parm2Value);
            if (!found || string.IsNullOrEmpty(parm2Value))
                throw new ArgumentNullException("parm2");
            JsonObject result = new JsonObject();
            result.AddString("parm1", parm1Value);
            result.AddString("parm2", parm2Value);
            return Encoding.UTF8.GetBytes(result.ToJson());
After adding this soe file to ArcGIS Server and invoke the rest service at:  http://localhost:6080/arcgis/rest/services/demo/MapServer/exts/RestSOE/sampleOperation?parm1=1111&pa...
the soe will throw ArgumentNullException when it trying to retrieve parm1 value.
Then I change handler code to:
            object parm1Value;
            bool found = operationInput.TryGetObject("parm1", out parm1Value);
            if (!found || parm1Value == null || string.IsNullOrEmpty(parm1Value.ToString()))
            object parm2Value;
            found = operationInput.TryGetObject("parm2", out parm2Value);
            if (!found || parm2Value == null ||  string.IsNullOrEmpty(parm2Value.ToString()))
            result.AddString("parm1", parm1Value.ToString());
            result.AddString("parm2", parm2Value.ToString());
            string aaa;
            found = operationInput.TryGetString("parm1", out aaa);
            if (!found || string.IsNullOrEmpty(aaa))
                result.AddString("parm1Exist", "False");
            else
                result.AddString("parm1Exist", "True");
then result json will be:
 "parm1": "1111",
 "parm2": "222",
 "parm1Exist": "False"
It looks like JsonObject.TryGetObject() function works fine while JsonObject.TryGetString() not working.
Am i right?
nicogis
If you write 11111 the jsonobject (operationInput) passed to delegate this
{"parm2":1111,"parm1":222}
it's created number and not string so if you can have string (number integer) you test TryGetAsLong ....
YanyiZhang
Yes, you are right. If I changed parameter to 111abc then JsonObject.TryGetString() function works.
But how can I make JsonObject treat integer 1111 as a string "1111" if I'm directly invoke rest api via http? Do I have to use TryGetObject() function and then convert object to string?
Thanks!
nicogis
json isn't strongly typed so there isn't help of info it cannot know if it'string or number. (in soe you pass a list of parameters but not its type). you test before if it is a number.
