Request Error Percent Alerts by the thousands since AGOL October 2025 Update
1706
7
10-24-2025 11:05 AM
DavidColey
MVP Frequent Contributor
Not quite sure where to post this.... since the October ArcGIS Online update, all of my portal hosted feature layers that participate in my various 'By Reference' collaborations with our ArcGIS Online host have begun to throw constant Request Error Percent errors:
Logged At Component Id Code Level
10/24/25, 2:00:48.165 PM
624
9,000
severe
Source Message
Hosted/Street.FeatureServer
Hosted/Street/FeatureServer: null
Just over and over and over....
Probably associated with Open data or Hub, because otherwise there are no issues with the portal hosted layers in either Portal or Online,  and the hosted server site remains stable and normal.
Anyone else?
Thanks!
@DerekLaw
Tags (1)
DavidColey
Good day -
The repeating SEVERE-level log entries reporting a source errror:
624
9,000
severe
Source Message
Has been resolved.  I do not know why, but once I re-enabled the services directory on our Hosting site, the log entries ceased.  After a 15 minute wait, I re-disabled the services director on the Hosting site, and the log entries reporting a null source error have remained absent.
So for us, the action re-enable re-disable the services directory solved this issue.
Eugene_Adkins
Don't know the answer, but interesting that your post and this post were made in very close proximity to each other. They both, at the very least, share the same code ... though the code could be somewhat "generic."
DavidColey
yeah I saw that too, but thought that situation is referring to a geocode service issue and I'm not seeing that with my local geocoder services.
DavidColey
sometimes these things take a while to cycle through after updates, so we'll see.  Everything else is nominal
DavidColey
Here is an ArcGIS Monitor Chart showing the number of failed requests for our ArcGIS Server Host Site from 10/13/2025 - 10/27/2025:
Note there are essentially zero failed requests to the entire site prior to the 10/22/2025 ArcGIS Online update.  We changed nothing about our hosting site or our hosted feature layers (or servers, nor have we applied any patches to the 11.5 environment - everything is fully patched for 11.5 prior to the Online update).
This has to be related to the Online update and how the layers are collaborated across from our portal to ArcGIS Online by reference.
But again, there appear to be zero problems with the site, the hosted layers, the collaborations or anything with the servers themselves, e.g. memory use or network.
Everything is working as expected.
I wouldn't even care except it's filling my logs
@RussRoberts
@JakeSkinner
Tags (1)
DavidColey
At least the Server logs are starting to show a different error message other than 'null'
Log Details
Logged At
10/28/25, 9:23:57.198 AM
Component Id
624
Code
9,000
Level
severe
Source
Hosted/SiteDevArea.FeatureServer
Message
Hosted/SiteDevArea/FeatureServer: Cannot invoke "com.esri.standardsql.query.Selection.getExpression()" because "<local6>.y" is null
Time
1761657837198
Type
SEVERE
User
null
Thread
Elapsed
0.0
Machine
mymachine.xyz.xyzx
Process
1340
RequestID
c41f7eb7-cab5-4ea4-8774-7874273fa204
MethodName
null
DavidColey
Good day -
624
9,000
severe
Source Message
DavidColey
Interesting side note on this - our hosted server site is a 2-machine cluster.  whenever we have to restart the machines (after Windows updates, etc) the logging error re-appears until I go into server admin and re-enable / re-disable the services directory.  Once I do that, the SEVERE log entries cease.
