Republishing Arcmap Runtime Cached Map Service to Pro Runtime results in "Single Fused Map Cache: false"
177
07-30-2024 12:20 PM
Royce_Simpson
I've republished an Arcmap mxd to Server 10.9.1 via Pro and am running into an odd issue where the service shows as being a cached map service on all fronts (in Manager, at the REST endpoint) but the "Single Fused Map Cache" property is set to "false" and when you run the service in the js viewer, it comes up as a normal, un-cached service.  How do I fix this and get this running as a cached map service again?
Below is the REST endpoint URL to the service.
https://agomaps.larimer.org/arcgis/rest/services/mapsCached/Aerials2012AndParcels/MapServer
Royce_Simpson
I've opened a support case on this.  Will report back as things progress.
