Remove Login To acces Mapservice
1169
12-28-2012 12:48 AM
BenouhoudAnass
Hello;
when i want to acces in my Mapservice with local adress 192.168... i can't, i want to remove login option in the Mapservice
Best regard
RichardWatson
Are you saying that you can access your map service with the machine name but when you change that to an IP address it does not work?  Please provide the URL that works, the one that does not work, and the error message you get.
Please clarify what behavior you desire with regards to the login.  Do you want a system which requires no logins?  Do you want to have a particular map service which does not require a login?  Do you wish to disable access to a map service?
BenouhoudAnass
i cant acces to Maservice in localhost and adresse IP .if a want to acces to may Rest link i m rederict to login page:  http://localhost:6080/arcgis/rest/login?redirect=http%3A//localhost%3A6080/arcgis/rest/services/Cart...
i  want a system which requires no logins.
thx
RichardWatson
Read the post from David Cordes on 7/10/12:
http://forums.arcgis.com/threads/61931-Disable-security-in-10.1
