Regular Expression in Batch Job Manager
4847
01-09-2015 12:09 AM
EdytaKorczynska
Hello,
On a copy of one of our Data ( .mxd )I created a new Product Library and set of validation statements in batch job manager. The statements are based on SQL but most of them have Regular Expression as well.  We have just loaded new version of ArcGIS (10.2.2) into the machine and loaded new Product Library and batch job. Everything works perfectly except one thing. When I open Reviewer Batch Job Manager to be able to update the rules I have to select Feature Classes and Feature codes and Regular Expression statements are not visible. I can easily update ones with SQL statements only, but the ones with Regular Expression do not show Regular Expression statements (SQL and notes – error messages are there).
At the same time everything works perfectly, so when I update any Feature Code and I try to put invalid attribution (invalid = not as stated in Regular Expression) the error message pops out.
I can update statements in Reviewer Bach Job Manager only when I open the original .mxd data (the one where I created them)
AndyOmmen
Hi Edyta,
Are you using the Set Data Source dialog via the Workspace button in the RBJM or pointing to the new feature class while editing the check? I've found that if you set the data source through the Set Data Source dialog that the check parameters appear while editing the check properties. Just click the Workspace button in the RBJM and the Set Data Source dialog will appear. Any data sources with broken paths will have a red "X" next to them which means you need to select that row and click Change Data Source. Navigate to the new feature class and you can then apply the update to all data sources. After doing this see if the regular expression configuration strings are still missing. I hope this helps.
Andy
EdytaKorczynska
Hi Andy,
Thanks for the message, it worked!!.
I tried the Source Data before but I linked it to the wrong path.
Thanks again, it will make my life so much easier
Edyta
