I have a SQL Server Database that I have enabled as an Enterprise Geodatabase 10.5
This enabled fine however it appears that I can only register tables/layers which are held in the dbo schema of the database. I have numerous other spatial tables which are held in other schemas which had been set-up prior to our upgrade to an Enterprise Geodatabase which it appears I cannot register with the Geodatabase as the option is greyed out when I right click on the layer in ArcCatalog 10.5.
I really don't want to transfer these tables to the dbo schema if I can avoid it. Can anyone advise how I can register these spatial tables with the Enterprise Geodatabase?
Thanks
