Register data store error - Machine: <machine name> [<databasename>: (null)]
13711
12
04-12-2015 07:51 PM
TimothyHales
Esri Notable Contributor
I am getting the following error when trying to register my database with my server.
ArcGIS 10.3
SQL Server 2012
Database authentication
JayantaPoddar
MVP Esteemed Contributor
Hi Timothy,
First, close all applications and restart ArcGIS Server Service.
I hope an SDE user has been created for the database you want to register ( Create Enterprise Geodatabase ). Connect to the database from ArcCatalog using the SDE user.
Once connected successfully, right-click the geodatabase > Properties.
Copy the .sde path and use this path to register the database in ArcGIS Server Manager.
Jay
Think Location
JayantaPoddar
Hi Timothy,
Jay
Think Location
TimothyHales
That worked for getting my database registered. Thanks!
JimenaMartinez
I have the same error
But this solution didn't work for me. Any other ideas?
DarwinQuispe
Hello,
In my case, the solution to this problem was install database client (PostgreSQL) in my ArcGis Server machine and in my ArcMap Machine
AntonioSan_José
I have the same problem and the solution neither works for me. PostgreSQL is installed in both machines and still doesn't work.
Any solution?
Regards.
Asrujit_SenGupta
MVP Regular Contributor
Please provide more info:
1. Where are you trying to Register the database with server: In ArcCatalog or from Server Manager..?
2. Which version of ArcGIS and PostgreSQL are you working with?
3. Is this a new installation and are you trying for the first time to register a database with server on this?
AntonioSan_José
From ArcCatalog
ArcGIS 10.2
PostgreSQL 9.6.1 in local
PostgreSQL 9.3.15 in server
Yes
I am going to update the version of PostgreSQL to 9.6.1 in the server and try again.
Asrujit_SenGupta
These are the PostgreSQL versions supported at 10.2.x:
Supported database versions
PostgreSQL 9.0.5 (64-bit)
PostgreSQL 9.1.3 (64-bit)
PostgreSQL 9.2.2 (64-bit)
System Requirements
PostgreSQL 9.6.x is not even supported at ArcGIS 10.5: PostgreSQL database requirements for ArcGIS 10.5—System Requirements | ArcGIS Desktop
Install a supported version of PostgreSQL database and try again.
AntonioSan_José
Ok, I'll try version 9.2.2.
Thank you for your quick response.
Regards!
