Reconcile Error:code500
2153
03-17-2021 03:38 PM
DaniellaSollitt
When I try to reconcile edits from a version it comes up with Error:code500.
What does this mean and how do I fix it?
DanPatterson
MVP Esteemed Contributor
Release notes for ArcGIS Pro 2.7—ArcGIS Pro | Documentation
BUG-000133821 Error 500: error in handling operation validateNewTopology if ArcGIS Server 10.8 Utility Network Update Subnetwork Patch is installed.
Sadly, there are numerous links on the support site
Esri Support Search-Results
If that is the same issue
... sort of retired...
DaniellaSollitt
Hello,
does this still apply as we are still using Pro 2.6?
by Anonymous User
Not applicable
Did you ever get this resolved? We just set up a version 4 UN on an Enterprise 10.8.1 and are using pro 2.6.7.
