Questions about Database and ArcSDE
14675
13
08-19-2013 02:44 AM
DominikSchlarmann
Over the weekend I've worked on setting up a database for my ArcGIS Server to enable WFS and Feature Access (editing, deleting, updating, creating features/attributes)
Some relevant information:
  • ArcGIS 10.2 installed on Windows Server 2012
  • PostgreSQL 9.2.2 64Bit is installed as well as PostGIS 2.0 http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#//015100000075000000
  • I've copied the necessary 32Bit client files into the \bin-Directory of my ArcGIS Desktop 10.2 installation.
  • I've copied the necessary 64Bit client files into the \bin-Directory of my ArcGIS Server 10.2 installation. I'm even not sure, if I need this....
  • I've copied the necessary st_geometry file into the \lib-Directory of my PostgreSQL 9.2.2 installation.
  • I've registered the database and the folder via the ArcGIS Server manager in the data store tab. (see attached screenshot).
  • The connection via pgAdmin work. I can connect to the database using pgAdmin.
  • The connection via ArcCatalog-> Add Database Connection is finally working. I can connect to the database.
No I'm at the point, where I have to create a Enterprise Geodatabase: http://resources.arcgis.com/en/help/main/10.2/index.html#//002p000000t4000000
I've filed in the required fields and the wizard tries to creta Enterprise Geodatabase for a long while, but doesn't come to an end. It stucks at the last step:
Executing: CreateEnterpriseGeodatabase PostgreSQL myarcgisserver,4321 ghana DATABASE_AUTH postgres ***** SDE_SCHEMA sde ***** # C:\Users\Schlomm\Desktop\keycodes
Start Time: Mon Aug 19 12:50:14 2013
User has privileges required to create database objects.
Geodatabase admin user created.
Database created.
Validated authorization file.
User has required privileges for geodatabase setup.
XML support is enabled for the database instance.
Connected RDBMS instance is setup for Esri spatial type configuration. For now about 20 minutes without any change.
My goal: Being able to set up and use Feature Access and WFS services.
So...are my performed steps right or did I miss anything?
I've read about path variables and enabling geodatabases, but I don't know what and how to perform these steps.
Additionally it would be very nice, if someone could tell me the advantages of using ArcSDE. For now I haven't installed this.
Would be nice, to hear some tips.
Thanks in advance,
Dominik
KimPeter
Completed successfully...? (I hope)
Out of curiosity, is your PostgreSQL server a VM?  Or possibly on a subnetwork?  39 minutes is an awfully long time for that tool to run.  Based on what messages are shown from the GP tool, you had all the right information and configuration needed for the tool to run successfully, so I wonder what would make it take so long.  I suppose it could be a network or hardware issue too, though.
by Anonymous User
Not applicable
Original User: ivv-splatz
Dear Kim,
Jepp...completed successfully. I was even able to go through the tutorial:
http://resources.arcgis.com/en/help/main/10.2/index.html#/Tutorial_Performing_web_editing_using_data...
And it works 🙂
You're right. My ArcGIS Server is running in a virtual box and additionally in another network. Not the ideal environment, but after some further testing I will switch to another server running with more GB RAM. For now I only have about 3.5GB RAM.
Thanks so much for your support:) I will definitely have further questions, so it's nice to know that there are people, who are willing to help me 🙂
Cheers,
Dominik
P.S.: Sorry for crosslinking, but during testing my Feature Access Service my problem with ArcGIS Online occurred several times.
http://forums.arcgis.com/threads/90764-ArcGIS-Online-gt-The-layer-lt-layername-gt-cannot-be-added-to....  Maybe you also have an idea? Could it be based on the same reason like using a VM?
P.P.S: I've installed PostGIS... is there any big advantage using PostGIS for a Feature Service?
DominikSchlarmann
Dear Kim,
And it works 🙂
Cheers,
Dominik
http://forums.arcgis.com/threads/90764-ArcGIS-Online-gt-The-layer-lt-layername-gt-cannot-be-added-to....  Maybe you also have an idea? Could it be based on the same reason like using a VM? IN my opinion it "must" be something different, because I don't get the error when I'm not logged in.
by Anonymous User
Not applicable
Original User: kpeter
Dominik,
Looks like you found the answer to your Online question.
As to whether you should use PostGIS for your feature services...the functionality through the feature service should be the same whether you're using PostGIS or ST_Geometry.
